KB88974
Published:
After PAC Control strategy is updated, groov View reports tags not available
GRV-EPIC-PR1
GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
GROOV-AT1, GROOV-AT1-SNAP
GROOV-SVR-WIN, GROOV-SVR-WIN-BASE, GROOV-SVR-WIN-SNAP
R4.2a and R4.2b
If you rename tags in a PAC Control strategy and update that strategy in groov View, groov View may continue to try to use the original tag names. Affected gadgets will show yellow triangles and report that the (older) tag is not available on the controller.
