KB88964
Published: February 11, 2021
Send Communication Handle Command Fails (-52 error) When Ethernet Cable Unplugged
  • SNAP-PAC-S2, SNAP-PAC-S2-W
R10.0h to R10.4a
R10.4c
When using an ftp communication handle in your PAC Control strategy with the command “Send Communication Handle Command”, it will fail with a -52 error under the following circumstances:
  • The Send Communication Handle Command uses the "send:" command.
  • The “send:” command string uses the IP address of the controller that the strategy is running on (i.e., not using the loopback address of 127.0.0.1).
  • The Ethernet cable is removed from the controller.
Do either of the following:
  • Leave the Ethernet cable connected.
  • Specify the loopback address (127.0.0.1) in the “send:” command string.
