KB88928
Published:
groov View: OPC-UA servers may return UnsignedByte values when Byte values are expected
GRV-EPIC-PR1
GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
GROOV-AT1, GROOV-AT1-SNAP
GROOV-SVR-WIN, GROOV-SVR-WIN-BASE, GROOV-SVR-WIN-SNAP
R4.2a and R4.2b
Gadgets connected to Byte or Byte Array tags on an OPC-UA server may show a yellow triangle, showing an error message like this:
The string is configured as a INT8_ARRAY, but the type returned from the server is UnsignedByte.
