KB88927
Published:
All groov View gadgets connected to the same OPC-UA scanner show yellow triangles
GRV-EPIC-PR1
GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
GROOV-AT1, GROOV-AT1-SNAP
GROOV-SVR-WIN, GROOV-SVR-WIN-BASE, GROOV-SVR-WIN-SNAP
R4.1a to current
If the OPC-UA server returns NULL results, groov View's OPC-UA scanner may disconnect from the server. Then all gadgets that are connected to that OPC-UA scanner show yellow triangles.
