KB88771
Published: May 5, 2020
For built-in firewall rules, tun0 can't be set to "deny"
Firmware for GRV-EPIC-PR1
1.4.0 to 1.5.0
2.0.0
The GRV-EPIC-PR1 has the following firewall rules built in (you can find them by clicking Security > Firewall from the groov manage Home page):
  • groov EPIC
  • OptoMMP
  • ModbusTCP
  • PAC Controller
  • CODESYS Controller TCP
  • CODESYS Controller UDP
  • Ignition Edge
  • Designer Access To Ignition Edge
For any of these built-in rules, if eth0 is set to allow, when you try to set tun0 to deny, that change is not saved. tun0 remains set to allow.
