KB88728
Published: May 23, 2023
Revision: 5.0
PAC Display Runtime: Inconsistent refreshing of graphics and values
PAC Display Runtime
R10.2c to R10.5a
R10.5b
If you have this issue, you might observe the following behaviors, inconsistently:
- The values in a graphic may not update.
- The values in a graphic may show upon initial loading of the graphic, but then don't update.
Another aspect of the inconsistent behavior is that:
- It doesn't happen on all PCs or on all projects.
- Even among the PCs and projects where the symptoms do occur, the results are sporadic. They may or may not be corrected by restarting PAC Display or the PC.
Several different actions may seem to resolve the issue:
- The problem window is closed and reopened
- The problem window or PAC Display Runtime is resized
- PAC Display is alternated between minimizing and maximizing.
The issue occurs only on Windows 10 and 11. Symptoms begin shortly after a Windows upgrade to these versions, and sometimes not until an upgrade of PAC Display.
