KB88441
Published: August 12, 2019
Communication to groov I/O unit disabled with -56 error
GRV-EPIC-PR1
All versions
In a PAC Control strategy that has a groov I/O unit, if a command results in a -56  "Invalid address" error in the control engine's message queue, communication to the groov I/O Unit becomes disabled. This error should not disable communication to the groov I/O unit.
Re-enable communication to the affected groov I/O unit.  We recommend implementing the logic from our example "I/O Enabler for Ethernet and SNAP PAC Brains” strategy.
