KB88414
Published: October 17, 2019
PAC Control: Can't enter hex value when you configure or edit an integer variable
PAC Control (Basic and Professional)
All versions prior to R10.2c
R10.2c
In PAC Control, when you configure or modify an integer variable and try to type in a hexadecimal value (for example, 0xA) in the Initial Value field, nothing happens. You should be able to enter a hexadecimal value.
Do either of the following:
  • Initialize the variable using the decimal value instead of the hexadecimal value.
  • In the Powerup chart, initialize the variable with the Move command, specifying the hexadecimal value as the To argument.
