KB88411
Published: August 27, 2019
Resetting GRV-EPIC-PR1 at start or end of RSS session may create unexpected behavior
Firmware for GRV-EPIC-PR1
1.2.0 to current
If you reset or cycle power to the GRV-EPIC-PR1 when starting or disconnecting from an OptoSupport Remote Support Service (RSS) session, unexpected behavior may occur.  For example, you may not be able to log into the GRV-EPIC-PR1.
Do not cycle power or reset the GRV-EPIC-PR1 when establishing or disconnecting from an RSS session. If the issue does occur, perform a Reset to Factory Defaults as described in groov EPIC User's Guide (form 2267).
