KB88409
Published: August 22, 2019
Comm handle values may not be set correctly on groov EPIC Serial Module
Firmware for GRV-EPIC-PR1
All versions prior to 1.4.0
1.4.0
In your PAC Control strategy, when you open a serial communication handle to a port on a GRV-CSERI-4 module, you may get garbled serial data. This is because some parameters may not get set according to the communication handle settings.
If possible, use 8 data bits and set parity to none.
