KB88377
Published: February 25, 2020
Certain PID loop options on groov EPIC I/O Units may not work
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
GRV-EPIC-PR1 firmware: All versions prior to 1.4.0
PAC firmware: All versions for SNAP PAC/SoftPac Controllers to R10.0g
GRV-EPIC-PR1 firmware: 1.4.0
PAC firmware: R10.0h
When you configure a PID loop on a groov EPIC I/O unit, the options to set the output or switch to manual mode when the PID input goes out of range may not work.
