KB88319
Published: October 17, 2019
In PAC Manager, watchdogs for digital outputs cannot be enabled
R10.2b
R10.2c
In the PAC Manager point configuration page for digital outputs, the watchdog enable field is grayed out and the watchdog cannot be enabled.
- On the point configuration page, right-click the memory map address for Watchdog Enabled/Disabled and choose Copy Address.
- Click Other > Generic Read/Write.
- Paste the memory map address into the Address field and click the Refresh button.
- In the Value field, change 00000000 to 00000001 and click Apply to enable the watchdog for the point.
- Then continue to set the watchdog output value.
