KB88302
Published: July 3, 2019
CODESYS: Can't configure Steinhart-Hart Coefficients for "Thermistor: Custom Curve" channel type
Opto 22 Library Package for CODESYS Development System
1.0.0.0 through 1.0.0.1
1.0.1.0
When you plug in a GRV-ITR-12 device into your CODESYS application and you select the channel type "Thermistor: Custom Curve (°C) (0x60000043)", the Parameters page doesn't offer a way to enter the Steinhart-Hart coefficients.
Add custom application code to your CODESYS application to enter the Steinhart-Hart coefficents directly to the OptoMMP memory map.
