KB88283
Published: June 14, 2019
PAC Display Configurator: Able to right-click on attribute check boxes
PAC Display Configurator (Basic and Professional)
All versions prior to R10.2b
R10.2b
When you are in the Graphic Dynamic Attribute dialog box (old or new), if you right-click on the checkbox icon, it cycles from blank, to checked, to blocked (a red diagonal line). This creates an incorrect indication of the state of the attribute.
Do not right-click on the checkboxes.
