KB88265
Published: August 22, 2019
Controller returns Status Code of -443 or -20 for HTTP Status Code of 204
Firmware for GRV-EPIC-PR1
Firmware for:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
All version for GRV-EPIC-PR1
9.5g to current for SNAP PAC/SoftPac Controllers
1.4.0 for GRV-EPIC-PR1
If you run an HTTP Post from String table command with an empty body, the PAC Controller should return a Status Code of 0 because the HTTP Status Code for an empty body is 204, which is a valid response. However, the Status Code it returns is:
  • If the controller is a GRV-EPIC-PR1 or SoftPac, it returns a -20 error.
  • If the controller is a SNAP PAC, it returns a -443.
