KB87999
Published: August 20, 2019
Can't set firewall rule on ports 22006 and 22007 for TCP or port 8502 for UDP
Firmware for GRV-EPIC-PR1
1.3.0 through 1.3.2
1.4.0
When you create a firewall rule for either of these situations, you get a message "Reserved for Opto rules". These situations should be allowed.
- When you select the TCP as the protocol and you specify port 22006 or 22007, or a port range that includes 22006 or 22007.
- When you select UDP as the protocol and you specify port 8502, or a port range that includes 8502.
If possible, select another port or port range.
