KB87876
Published: August 20, 2019
Background download setting returns to disabled after power cycle
Firmware for GRV-EPIC-PR1
1.2.1 through 1.3.2; may be in earlier versions
1.4.0
If you enable Background Downloading (found in the control engine configuration page), then the GRV-EPIC-PR1 is turned off, then on again, Background Downloading returns to disabled.
Enable Background Download setting after cycling power on the GRV-EPIC-PR1.
