KB87788
Published:
Control engine stops running
Firmware for GRV-EPIC-PR1
1.0.0, 1.0.1, 1.1.0, 1.2.0
If you try to run a strategy that contains a SNAP I/O unit, with the primary address assigned, and the secondary address blank, the control engine stops running.
- Assign the I/O unit's actual address as the primary address.
- Assign an invalid address or hostname as the secondary address.
- Run the strategy.
- You'll see errors in the Message Queue stating that communications with the I/O unit failed. Verify that these errors apply only to the secondary address.
- Examine the I/O unit to verify that it is enabled.
