KB87601
Published: August 8, 2018
Revision: 1.1
"Edit > Replace > Entire Project" may fail or cause PAC Display to crash when replacing "File Name From Strategy" tag
PAC Display Configurator Basic
PAC Display Configurator Professional
Basic R6.2a/Pro R7.0a through R10.0b, and Beta versions B10.0c (all builds through 0015)
R10.1a
Replacing a tag name project-wide ( Edit > Replace > Entire Project) may fail without displaying an error message—or PAC Display Configurator may even crash—if the tag you're trying to replace is used in the String Name field in a historical data log (Log To > From strategy > String Name).
Manually change the tag instead of using the Edit > Replace command.
