KB87569
Published: August 20, 2019
Gateway IP address from one interface overrides gateway IP address of another interface
Firmware for GRV-EPIC-PR1
All versions prior to 1.4.0
1.4.0
This issue occurs only when you configure multiple network interfaces, where one is configured with IPv4 method "Manual (Static)" and the other is configured with IPv4 method "Automatic (DHCP)".
In the Network page (groov Manage Home > System > Network), if you change the Gateway method to Manual for one interface and provide a gateway IP address, the network interface configured with "Automatic (DHCP)" will override the gateway IP address of the manually configured gateway.
