KB86860
Published: October 17, 2019
Closing a chart using the corner x while a script block is open causes PAC Control to shut down
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Pro)
R9.6 to R10.2b
R10.2c
When you close a chart using the ‘x’ in the upper right corner while a script block in that chart remains open, you receive a message that PAC Control has to shut down because it stopped working correctly.
Close the script block window before you close the chart window containing the script block.
