KB90098
Published: March 9, 2022
"Move Numeric Table to I/O Unit" command doesn't work correctly on serial B3000 analog I/O units
Firmware for the following:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
R10.4c
R10.4d
When using the Move Numeric Table to I/O Unit command on serial B3000 analog brains, the firmware only writes the table elements to every other module.
