GRV-ITMI-8
GRV-ITMI-8
$855.00 (USA and Canada only)
Analog input, 8 channel, thermocouple or mV, channel-to-channel isolation
The GRV-ITMI-8 analog module is part of the groov EPIC® system. This flexible module provides 8 channels of input from millivolt or thermocouple field devices. Each channel is individually configurable for ±1200 mV, ±600 mV, ±300 mV, ±150 mV, ±75 mV, ±50 mV, ±25 mV or Type B, E, J, K, N, R, S, or T thermocouples.
The eight channels on the module are isolated from each other. Since these channels do not share any common connections, you can use grounded sensors and field devices with them.
The GRV-ITMI-8 mounts on a groov EPIC chassis with a GRV-EPIC-PR1 processor and additional analog, discrete, and serial groov I/O modules, to provide the mix of signals you need at any location.
Specification GRV-ITMI-8
Millivolt Input Ranges ±1200.0 mV, ±600.0 mV, ±300.0 mV, ±150.0 mV, ±75.0 mV, ±50.0 mV, ±25.0 mV
Over range limits (± 10%) ±1320.0 mV, ±660.0 mV, ±330.0 mV, ±165.0 mV, ±82.5 mV, ±55.0 mV, ±27.5 mV
Resolution mV Range / 1,048,576 (20 bits)
Accuracy 0.1% of Range ±1200 µV, ±600 µV, ±300 µV, ±150 µV, ±75 µV, ±50 µV, ±50 µV
Thermocouple ITS90 Types Accuracy* / Resolution
B: 90 °C to 1,820 °C (194 °F to 3,308 °F) 5.0 °C (9.0 °F)/ 0.05 °C (0.1 °F)
E: -270 °C to 1,000 °C (-454 °F to 1,832 °F) 2.0 °C (3.6 °F)/ 0.05 °C (0.1 °F)
J: -210 °C to 1,200 °C (-346 °F to 2,192 °F) 2.0 °C (3.6 °F)/ 0.05 °C (0.1 °F)
K: -270 °C to 1,372 °C (-454 °F to 2,501.6 °F) 2.0 °C (3.6 °F)/ 0.05 °C (0.1 °F)
N: -270 °C to 1,300 °C (-454 °F to 2,372 °F) 3.0 °C (5.4 °F)/ 0.05 °C (0.1 °F)
R: -50 °C to 1,768 °C (-58 °F to 3,214.4 °F) 5.0 °C (9.0 °F)/ 0.05 °C (0.1 °F)
S: -50 °C to 1,768 °C (-58 °F to 3,214.4 °F) 5.0 °C (9.0 °F)/ 0.05 °C (0.1 °F)
T: -270 °C to 400 °C (-454 °F to 752 °F) 3.0 °C (5.4 °F)/ 0.05 °C (0.1 °F)
Cold Junction Compensation Automatic
Data Freshness (nominal) mV Ranges = 21 ms / T/C Ranges = 46 ms
Analog Data Filtering -3 dB @ 2.4 Hz / -25 dB @ 60 Hz
Software Data Filtering, simple moving average (SMA) and Weighted filter SMA: 1 to 32 readings
Filter Weight: 1 to 4096
Step Response Time (to 1%) 85 ms
Common Mode Rejection > -120 dB AC/DC
Input Resistance 100 megohm
Problem Indication out of range, open thermocouple
Isolation (field-to-logic) 300 V working, 1500 V transient (1 minute)
Isolation (channel-to-channel) 300 V working, 1500 V transient (1 minute)
Number of Channels 8
Chassis Power Consumption 1.4 W
Wire Size 28–14 AWG
Torque, connector screw 2.5 in-lb (0.28 N-m)
Torque, hold-down screw 3.5 in-lb (0.4 N-m)
Humidity (non-condensing) 5–95% RH
Agency Approvals UL/cUL (Class 1 Div. 2); CE, ATEX (Category 3, Zone 2), RoHS; DFARS; CB Scheme
Warranty Lifetime
Type - + Range
B Red Gray +42 °C to +1,820 °C
E Red Purple -270 °C to +1,000 °C
J Red White -210 °C to +1,200 °C
K Red Yellow -270 °C to +1,372 °C
N Red Orange -270 °C to +1,300 °C
R,S Red Black -50 °C to +1,768 °C
T Red Blue -270 °C to +400 °C
groov Analog Thermocouple/Millivolt Input Module Data Sheet
The groov® analog thermocouple/millivolt input modules are part of Opto 22's groov EPIC® System. This document includes descriptions, specifications, and wiring and dimensional diagrams for the thermocouple/millivolt input modules.
Declaration of Conformity (GRV-EPIC)
CAD Drawing: groov I/O Module
GRV-ITMI-8 Module Firmware
This download contains current firmware for the GRV-ITMI-8 module. For a list of bug fixes and enhancements included in this firmware, see the groov I/O Modules Firmware readme document.
You can download the previous version of the firmware by clicking on this link: 1.2d
Accuracy vs Resolution
