KB91448
Published: May 6, 2026
PAC Control strategy commands Calculate & Set Analog Offset and Calculate & Set Analog Gain return 0.0 for groov I/O or groov RIO channels
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
Firmware for the following SNAP PAC controllers:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
All versions
When calibrating analog channels on groov I/O or groov RIO modules using the Calculate & Set Analog Offset and Calculate & Set Analog Gain PAC Control strategy commands, the commands return a value of 0.0 instead of the required value.
To calibrate the offset and gain for groov I/O and groov RIO analog channels:
