KB91425
Published: April 14, 2026
Multiple UDP connection attempts with invalid connect strings may reset SNAP PAC controller
Firmware for:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
R9.0a to current
If a strategy uses the Open Outgoing Communication command multiple times with improperly formatted UDP connect strings, the affected controller may reset.
Verify the UDP connection strings are properly formatted. See the PAC Control User’s Guide (form 1700) for more information.
