KB91390
Published: July 30, 2026
Combo box with graphic dynamic attributes may not function in PAC Display Runtime
PAC Display Runtime Basic
PAC Display Runtime Professional
R10.5c to R10.6b
R10.6c
In PAC Display Runtime, when closing and reopening a window that has a combo box with graphic dynamic attributes, the combo box may not function.
In PAC Display Configurator:
  1. Open the window that contains the combo box.
  2. Right-click the background of the window and select Properties from the pop-up menu.
  3. Under Runtime Options, check Always in memory (fastest access).
  4. Click OK and save the project.
  5. Open the project in PAC Display Runtime like normal.
