KB91386
Published: March 2, 2026
Error message when trying to create Data Service server certificate with fixed IP address
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
3.5 (may affect earlier versions) to 4.0.3
4.1.0
When you try to create a certificate for the Data Service (from the groov Manage Home page, click Data Service > Configure > Server Certificate, then click Create Certificate) and you specify a static IP address in the Server Name field, when you click Create, groov Manage displays the following error message and does not create the certificate:
Failed to create a new server certificate or restart the server.
