KB91370
Published: December 30, 2025
SNAP analog points converted to G1 analog points after import through PAC Manager
Firmware for the following SNAP PACs:
  • SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B, SNAP-PAC-R1-GEN2
  • SNAP-PAC-EB1, SNAP-PAC-EB1-FM, SNAP-PAC-EB1-W
  • SNAP-PAC-EB2, SNAP-PAC-EB2-FM, SNAP-PAC-EB2-W
  • SNAP-PAC-SB1, SNAP-PAC-SB2
All versions
If you are using PAC Manager's Import/Copy I/O Unit Image feature to create a new I/O unit from an existing SNAP PAC I/O unit configuration, under the following circumstances, PAC Manager converts any SNAP PAC analog modules to G1 analog modules:
  1. Save the SNAP PAC I/O unit configuration to flash.
  2. Restart the SNAP PAC I/O unit.
  3. Import the SNAP PAC I/O unit configuration from flash memory.
Save the I/O unit configuration to flash, then import the configuration from flash without restarting the unit between those two tasks.
