KB91213
Published: October 24, 2025
Updating module firmware in PAC Manager may fail if firmware filename contains a parenthesis
All versions prior to R10.6a
R10.6a
When attempting to install module firmware in PAC Manager, you may encounter a “Command Failed” error message if the module firmware filename contains a parenthesis.
For example, if the original filename is snap-aiv-r2.1b.eio and you attempt to install a firmware file named snap-aiv-r2.1b (1).eio, you may encounter the error message and the update fails.
Ensure the module firmware file does not contain a parenthesis in its filename.
Copyright © 2025 Opto 22. All rights reserved.
