KB91187
Published: June 4, 2025
Duplicating graphic objects in PAC Display may fail with a misleading error message
PAC Display Configurator Basic
PAC Display Configurator Professional
R10.2a to current
When using the Duplicate function (Edit > Duplicate) to copy graphic objects in PAC Display, the graphics may fail to copy, and a misleading error message appears.
Perform a copy/paste of the graphic objects instead of duplicating them. For more information, see the “Copying, Duplicating, and Pasting” section in Chapter 6 of the PAC Display User’s Guide (form 1702).
Copyright © 2025 Opto 22. All rights reserved.
