KB91176
Published: May 16, 2025
During EPIC boot up, GRV-OVMAILP-8 voltage outputs may not be at zero volts
Firmware for GRV-OVMAILP-8
All versions prior to 1.3d
1.3d
When a groov EPIC unit with a GRV-OVMAILP-8 module is booting up or when the module is hot swapped, any channels configured as a voltage output may output a non-zero voltage for a few seconds.
Connect a resistor (approximately 10 to 100 kOhms) across the terminals of each channel configured as a voltage output.
Copyright © 2025 Opto 22. All rights reserved.
