KB91168
Published: April 17, 2025
Some full-feature groov I/O modules may disrupt communication with groov I/O simple and serial modules
Firmware for the following affected groov I/O modules:
  • GRV-IDC-24
  • GRV-IDCI-12
  • GRV-IACDCTTL-24
Modules manufactured between November 10, 2024 and February 10, 2025 with serial numbers from 984512 up to and including 991333.
1.4a
If an affected groov I/O module is inserted in one of the first five slots (positions 0 through 4) of the chassis, groov simple modules in positions 0 through 7 and groov serial modules (only supported in positions 0 through 3) may encounter communication issues and be unable to connect. The module LED color may or may not indicate an issue.
Rearrange the modules on the chassis based on the following:
  • If you have groov serial modules (only supported in positions 0 through 3) and groov simple modules in positions 0 through 7, do not place an affected module in positions 0 through 4 of the chassis.
  • If you do not have groov serial modules but have affected groov modules in positions 0 through 4, do not place groov simple modules in positions 0 through 7 of the chassis.
After rearranging the modules, some modules may not recover until:
  • Power to the chassis is turned off for several seconds and then turned back on
  • The affected groov simple modules are removed from the chassis and then reinserted (hot-swapped)
