KB91163
Published: June 11, 2025
The user-supplied MQTT Sparkplug client ID is ignored
Firmware for the following groov EPIC:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.6.0
For groov RIOs: 3.6.0 to 3.6.1
4.0.0
If you configured the MQTT Sparkplug client on your groov EPIC or RIO to connect to an MQTT broker with a specific MQTT client ID, the configured MQTT client ID is ignored and a randomly generated client ID is used.
