KB91101
Published: October 24, 2025
Consecutive variable imports using .csv files crash PAC Control
PAC Control Basic
PAC Control Professional
All versions prior to R10.6a
R10.6a
When attempting another variable import after a successful variable import using comma-separated values (.csv) files, PAC Control may crash.
If you need to run multiple variable imports (even if using the same .csv file), save and close the strategy after each import, and then reopen the strategy to perform the next import. Repeat for each import as needed.
