KB91017
Published: June 11, 2025
Get Date & Time command may not retrieve milliseconds atomically
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
All versions prior to 4.0.0
4.0.0
If you use the PAC Control Get Date & Time command, the milliseconds may not have been obtained at the same moment as the other values (hours, minutes, and seconds) were obtained.
