KB90990
Published: September 30, 2025
Converting date/time from integer 32 table to NTP and then back may introduce 1 msec discrepancy
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for the following SNAP PACs:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B, SNAP-PAC-R1 (GEN2)
For groov EPICs: All versions prior to 4.0.0
For SNAP PACs: All versions prior to R10.6a
For groov EPICs: 4.0.0
For SNAP PACs: R10.6a
If you run a series of commands to convert date/time from integer 32 table to NTP time stamp and then back to integer 32 table, you may occasionally observe a 1 msec discrepancy introduced during the conversion.
Copyright © 2025 Opto 22. All rights reserved.
