KB90968
Published: June 11, 2025
Command to delete a file fails if file name contains ~ character
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 4.0.0
4.0.0
If your PAC Control strategy has a command to delete a file where the ~ character is in the file path (for example, SendCommunicationHandleCommand( chFile, "delete" ), where chfile was set to "file:r,~/unsecured/MyTest.txt"), the command returns a -408 (File Access) error.
Specify the entire path.
Copyright © 2025 Opto 22. All rights reserved.
