KB90947
Published: July 24, 2024
The “Subtype / Feature” column in PAC Control may display incorrect channel information for GRV-IDCIFQ-12 modules
PAC Control Professional
PAC Control Basic
R10.5b to current
In PAC Control Configuration mode, the Subtype / Feature column of the Configure I/O Modules and Points window may not display the correct values for channel type and feature of GRV-IDCIFQ-12 modules when they are automatically added. For example, “Generic Type” incorrectly displays as the Subtype for channels 0, 1, 3, 4, 6, 7, 9, and 10 when all channels should be “2.5-30VDC with Quadrature Index”.
