KB90935
Published: June 11, 2025
Warning messages repeated from apt-get update command
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.6.0
4.0.0
This issue applies only to shell users.
When you run the sudo apt-get update command, you may see messages like the following repeated many times:
W: Target Packages (Packages) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list:5
W: Target Translations (en_US) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list:5
W: Target Translations (en) is configured multiple times in /etc/apt/sources.list:1 and /etc/apt/sources.list:5
The
sudo apt-get update command is functioning correctly.
You can ignore the warnings.
Copyright © 2025 Opto 22. All rights reserved.
