KB90925
Published: June 11, 2025
groov EPIC may restart while using groov View on a monitor plugged into the EPIC
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 4.0.0
4.0.0
If you have groov View running on an external monitor plugged into the groov EPIC, you may occasionally observe that the groov EPIC restarts.
Periodically restart the external display by using groov Manage:
- From the groov Manage Home page, click System > Display.
- Click Restart Display.
Copyright © 2025 Opto 22. All rights reserved.
