KB90875
Published: June 17, 2024
Tags deleted/modified on groov EPIC/RIO continue to show valid value in OPC UA client
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.5.1
For groov RIOs: 3.4.0 to 3.5.0
For groov EPICs: 3.6.0
For groov RIOs: 3.6.0
When you delete or modify tags (on groov EPICs, that could be by either downloading a new PAC Control strategy or modifying the public attributes of I/O channels; on groov RIOs, that could be by modifying the public attributes of I/O channels), the Data Service's OPC UA server should report these tags as "bad" quality. However, with this issue, the Data Services OPC UA server may still report a valid value.
Restart the Data Service:
  1. Log into your groov EPIC or groov RIO with an ID that has system administrator permission.
  2. From the groov Manage Home page, click Data Services.
  3. In the Status section, click Disable on the Data Service Runtime field.
  4. After the Data Service field changes to Disabled, click Enable. Wait for the Data Service field to change to Running.
