KB90874
Published: May 22, 2024
PAC Control COM handle with ‘b’ to open a file fails with -6 error code
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
3.3.0 to 3.5.1
3.6.0
On your groov EPIC processor, if you have a PAC Control strategy that uses a communication handle (COM variable) to open a file that specifies b for the mode, the open fails with a -6 (Invalid Data Field) error.
The b specifies binary, which is the default mode for opening a file. Omit the b.
