KB90870
Published: May 22, 2024
OPC UA tag browsing may time out when opening folders with large number of tags
groov View running on the following groov EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
groov View running on the following:
  • GROOV-SVR-WIN
  • GROOV-SVR-WIN-BASE
  • GROOV-SVR-WIN-SNAP
For groov EPICs: 3.4.0 to 3.5.1
For all othres: R4.4a to R4.5b
For groov EPICs: 3.6.0
For all othres: R4.5c
While browsing through tag folders from an OPC UA catalog, if you click on a folder with such a large number of tags (may be more than thousands) that a read timeout is exceeded and the browser may remain stuck, displaying Retrying on that folder.
In the groov View logs, you may see messages like the following:
[java] 23:26:27 WARN  [qtp230835489-20] com.allen_sauer.gwt.log.client.Log - JsonRpcClient::responseError - An error occurred while trying to send request id 'browseNode_4', method 'browseNode.
[java] 23:26:27 INFO  [qtp230835489-20] com.allen_sauer.gwt.log.client.Log - OpcUaNodeTreeNode::browseTags - a browser error occurred while trying to browse 'opc.tcp://your-opc-ua-server:4096'; this may be a timeout, so I'm retrying.
Divide the tags into separate folders so each folder contains fewer tags.
