KB90833
Published: June 17, 2024
Revision: 4.0
When downloading "Support Download" file, contents may be truncated
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.5.1
For groov RIOs: 3.4.0 to 3.5.0
For groov EPICs: 3.6.0
For groov RIOs: 3.6.0
When you click Download from the Download Support Info page (from the groov Manage Home page, click Info and Help > Support Download), all the contents from the generated report displayed in the page should be saved into a text file. With this issue, only a portion of the content is saved into the text file. This issue occurs if there are certain special characters (; / ? : @ & = + $ , #) in the text.
Try one of the following:
  • To obtain the full content of the Support File, after you click Generate, highlight all of the text, and then paste it into a text file. The following instructions work from a Windows® browser:
    1. From the groov Manage Home page, click Info and Help > Support Download.
    2. Click Generate at the top of the page.
    3. Place your cursor anywhere in the text and press CTRL+A. All of the text is highlighted.
    4. Press CTRL+C to copy the selected text.
    5. In a text editor, open a new file and press CTRL+V.
    6. Save your file, including helpful information in the name like date and time.
  • If possible, remove special characters from I/O channel names.
