KB90789
Published: June 17, 2024
MQTT and OPC UA may display a variety of symptoms due to scan/communication timeout
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.5.1
For groov RIOs: 3.4.0 to 3.5.0
For groov EPICs: 3.6.0
For groov RIOs: 3.6.0
You may have this issue if you observe the following behaviors:
  • MQTT with Sparkplug payloads: publishes a Sparkplug Device Death followed by a Device Birth on the OptoMMP device.
  • MQTT with String payloads: could intermittently publish all of the OptoMMP device’s tags.
  • OPC UA tags may briefly show bad quality.
