KB90767
Published: June 17, 2024
Can't view unsecured files on groov RIO
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-IVAPM-3
3.5.0
3.6.0
From the groov Manage Home page, if you click System > Files, then Unsecured Files, groov Manage displays the message Nothing is mounted
, even if there are files in the unsecured area.
If you have been adding files to the unsecured area through programming (for example, Node-RED or CODESYS), use file management programming techniques available through those platforms to obtain the list of files stored in the unsecured area.
