KB90750
Published: May 22, 2024
Revision: 4.0
Clear All Latches may command cause -95 Info message
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for the following SNAP PACs:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
For groov EPICs: All versions prior to 3.6.0
For SNAP PACs: R8.5a to R10.4d
For groov EPICs: 3.6.0
For SNAP PACs: R10.4e
If the argument to the Clear All Latches command is a pointer variable that is NULL, a -95 info message (Data stack not empty) is placed on the controller's message queue.
Before using this command, use the "Pointer Equal to Null?" condition to ensure the pointer is not NULL.
