KB90706
Published: August 31, 2023
After firmware upgrade, Data Service becomes unresponsive when you try to enable it
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.5.0
3.5.1
If you do either of the following on your groov EPIC, when you attempt to enable Data Service, you may see the error message "Starting up server threw null" and the Data Service page becomes unresponsive.
- Upgrade to firmware version 3.5.0 with the Back Up Settings option enabled.
- Upgrade to firmware version 3.5.0 and attempt to restore Data Service options with a back up made from firmware earlier than version 3.5.0.
Do the following:
- Log in to your groov EPIC with an ID that has system-level privileges.
- Click Data Service.
- Click Disable, if the service is enabled.
- Click Configure.
- Click the configured OPC UA device.
- In the Configuration section, type in any IP address in the Additional Endpoint field.
- Click Save.
- Click the configured OPC UA device, again.
- In the Configuration section, remove the IP address you typed in the Additional Endpoint field.
- Click Save.
- Click Status to return to the Data Service page.
- Click Enable to start the Data Service.
