KB90702
Published: October 6, 2023
Clear All Latches command may cause processor/controller reset
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
Firmware for the following SNAP PACs:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
For groov EPICs: 3.5.0
For SNAP PACs: R9.2a to R10.4d
For groov EPICs: 3.5.1
For SNAP PACs: R10.4e
If your PAC Control strategy uses the Clear All Latches command on a SNAP I/O unit that has unconfigured points or empty module positions, the groov EPIC processor or SNAP PAC controller will reset.
Do one of the following:
  • Make sure all points on all modules are configured.
  • Clear latches on individual points with the Clear On-Latch or Clear Off-Latch commands.
