KB90700
Published: August 31, 2023
E2 analog inputs report a constant, invalid value
For units to be affected, both of these must be true:
- On the component side, a sticker indicating 9298d or 9298e, and
- on the non-component side (underside), a date code in the range of 05/22 to 08/23 (May 2022 to August 2023).
If you are affected by this issue, any of the following combination of channels stop measuring inputs and report 0 counts or 61440 counts (if configured to read counts) or an invalid engineering unit value (if configured to read engineering units):
- Channels 0 through 7
- Channels 8 through 15
- All channels
Cycling power to the E2 temporarily clears the issue.
If you experience this issue, contact the Opto 22 Product Support Group to send in the affected units to be updated.E-mail: support@opto22.comPhone: 951-695-3080
